Details
Temperature range covers ? °C.
- Holds capillaries 1.0 mm in diameter.
- Best to fill samples >=20mm.
- We recommend sealing with Devcon 5 Minute or 2 Ton Epoxy. If you have not used these before, you may need some practice to get a feel for the mixing and hardening times.
- Works for glass/quartz capillaries and kapton capillaries; quartz capillary is preferred because of its high mechanical strength. Commercial Sources: Hampton | Charles Supper
