Details
For Bio or other aqueous samples (non-capillary).
- Samples should be well labeled either on the cap or the side, volume >=140 uL, and ready to go after centrifugation.
- If labeling on the tube side/body, use permanent marker only (no tapes), otherwise the tubes will be too fat to fit in the sample holder.
- Tubes are run using a home-made autosampler.
